Solved
There is a problem with routing in Extreme X460G2
  • 13 September 2019
  • 1 reply
  • 888 views
One of our switch core Extreme X460G2 had this problem when adding a new static route, the logs about are:
LN_Extreme.3 # show log
12-Sep-2019 17:46:06 IPv4 route not added to hardware. Reached configured # of IP Route reserved-entries. (Logged at most once per hour.)
12-Sep-2019 17:46:04 [VR 0x00000002] Peer 10.101.1.2 (0) has entered or left Established state, EST? 1, holdtime: 30, passive: 0
12-Sep-2019 15:58:45 vrId 2 dest 200.1.183.152:32 nexthop 10.101.1.162: DEFIP add uninstalled: Entry exists (-8): cannot add - ref 1, ins 0
12-Sep-2019 15:58:45 vrId 131074 dest 200.1.183.152:32 nexthop 10.101.1.162: Unable to add route to unit 0, rc Entry exists. Shadow problem.
12-Sep-2019 15:58:44 [VR 0x00000002] Peer 10.101.1.2 (0) has entered or left Established state, EST? 0, holdtime: 30, passive: 0
* LN_Extreme.5 # show switch
SysName: LN_Extreme
SysLocation:
SysContact: support@extremenetworks.com, +1 888 257 3000
System MAC: 00:04:96:99:9E:40
System Type: X460G2-48x-10G4
SysHealth check: Enabled (Normal)
Recovery Mode: All
System Watchdog: Enabled
Current Time: Thu Sep 12 23:31:48 2019
Timezone: [Auto DST Disabled] GMT Offset: -300 minutes, name is PERU.
Boot Time: Tue Jan 23 00:50:01 2018
Boot Count: 42
Next Reboot: None scheduled
System UpTime: 597 days 22 hours 41 minutes 46 seconds
Current State: OPERATIONAL
Image Selected: primary
Image Booted: primary
Primary ver: 22.3.1.4
patch1-4
Secondary ver: 21.1.3.7
Config Selected: primary.cfg
Config Booted: primary.cfg
Config Automatic: NONE
primary.cfg Created by ExtremeXOS version 22.3.1.4
2003959 bytes saved on Tue Sep 10 22:10:53 2019
LAA MAC: Locally Administered MAC Address Disabled
* LN_Extreme.6 #
I have read this article https://gtacknowledge.extremenetworks.com/articles/Solution/Info-Kern-IPv4FIB-Info-Slot-IPv4-route-not-added-Reached-configured-of-IP-Route-reserved-entries-Logged-at-most-once-per-hour , but I didnt find any problem
Please help me, I think it coud be a bug.
icon
Best answer by Erik Auerswald 13 September 2019, 13:06
this does not look normal to me. I would suggest you open a case with Extreme's GTAC (possibly via your support partner).
Thanks,
Erik
View original
1 reply
Userlevel 7
Thanks,
Erik
Reply
