AP 3805 yellow LED power
Userlevel 6
Hello, all!
Have an AP3805i.
Install guide say that power LED can be red or green
But in my AP3805i only power LED is yellow and steady
Any ideas?
Thank you!
Userlevel 4
Hi Alexandr,
Is it a brand new AP or was it working before?
Regards,
Nathiya M
Userlevel 6
Hi, Nathiya!
AP was working before, but at one time suddenly stuck with yellow power LED.
Switch with connected AP even can't see MAC address of this AP, so I understand that problem with booting.
But why LED is yellow?
Thank you!
Userlevel 5
Alexandr P wrote:
Hi, Nathiya!
Thank you!
Hello Alexandr,
The color looks like Amber.
It looks the AP initial and discovery in progress via WDS.
Here is the reference, Although the AP mode is difference, I believe that it will be the same
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-do-the-AP3610-LED-colors-represent
Best regards,
Userlevel 6
Alexandr P wrote:
Hi, Nathiya!
Thank you!
Hello, Bin!
1. From your link:
LED 1 Only
Solid Amber - Discovery finished via WDS, but not in progress.
(in one port of switch is EWC in other port is AP, they in one VLAN)
2. I can't see MAC address of this AP on switch port.
Thank you!
Userlevel 4
Hello Alexandr,
I think there's an typo on the install guide and "On Red" should be "On Amber".
Quick install guide implies it has Green and Amber colors only on the led.
Install guide for AP3825 says amber means a failure as below.
So how about open a case and I think this will probably be subjected to an RMA.
Thank you.
Userlevel 6
Roy Noh wrote:
Hello Alexandr,
Thank you.
Thank you, Ron!
I'll open case.
Userlevel 4
Roy Noh wrote:
Hello Alexandr,
Thank you.
How was it going? I am just curious.
By the way, I'm Roy 🙂
Have a nice holidays!
Userlevel 6
Roy Noh wrote:
Hello Alexandr,
Thank you.
Hello, Roy!
First of all - sorry for my mistake.
I opened case and RMA accepted for now.
Thank you!
Userlevel 4
Roy Noh wrote:
Hello Alexandr,
Thank you.
Sounds great.
Then I will send an email for correcting the wrong information.
Thank you 🙂
Reply
