how to connect to extreme identify wireless c35 by using console port?
ı don't connect this device with admin ports by using console cable
Userlevel 7
Take a look at https://gtacknowledge.extremenetworks.com/articles/Q_A/Using-the-Console-Port-on-the-IdentiFi-Wirele...
Userlevel 4
The below article should help with connecting using the console port.
- Sam
I tried this but it does not
Userlevel 7
Are you using the correct cable?
yes of course
Userlevel 7
try rebooting the c35 with the console attached, hit enter a few times after the power cycle to see if anything prints to the screen
it does not work .the another thing is that devices's digital screen has no prints.
Userlevel 7
I saw that too, sorry this happened. That's why I was hoping you could at least see the bootup cycle and try to recover.
I would contact the GTAC at this point... https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-contact-Extreme-Networks-Global-Tec...
thanks
Userlevel 4
Selam Hasan,
try serial port 115200 and it should work.
Regards
Umut Aydin
selamlar,
denedim ancak olmadı.reset attım ama yine olmadı ön taraftaki digital ekranda siyah çizgiler mevcut bu cihazın bozuk olduğunu gösterir mi?
Userlevel 4
Merhaba,
digital ekrani aletin üretici firmanin kullandigini tahmin ediyorum. Bizim programda/Wifi kullanima kapali onun icin herhangi bir sonuc elde edemiyoruz. Ama hersey denendigine göre aletin degistirilmesinde bence bir sakinca yok. Buna ragmen Case acmaniz lazim orda arkadaslar size yardimci olacaklar.
Iyi isler
Umut Aydin
#########FYI
Changig serail port doesn't work as well .
Please open a case and replace the controller.
Reply
