Problem with C25 Controller WIFI
Config Manager has suffered a critical error and will halt. Error Details: Failed to connect to database 'controllerConfig': Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (111)
Userlevel 6
Bruno
There isn't much information to go on here, you should consider opening a case with GTAC and provide a technical support file for analysis.
This article might also help: https://gtacknowledge.extremenetworks.com/articles/Solution/V2110-Can-t-connect-to-local-MySQL-server-through-socket-var-lib-mysql-mysql-sock
-Gareth
Thanks Mitchell,
i open a case for this issue.
Regards
Bruno T.
Reply
