Question
wireless speed issues with AP3821i
  • 18 July 2020
  • 1 reply
  • 81 views
Hello
Having strange issue with using the AP3825i.  We currently have 650 Mbps download and for some reason non of the clients can get speeds above 320 Mbps when testing.
I see no issues when they connect to ubiquiti unifi and consistently get speeds over 500 Mbps.
Any ideas what settings I can play with? Currently connecting on 5Ghz AC with 80Mhz.
1 reply
Userlevel 7
Do you mean data rate ?!
Please post a screenshot of the radio#1 settings window (+ the advanced radio#1 window) of the AP and tell us the model of the other vendor.
Also please specify the SSID configuration parameters.
-Ron
BTW: 80MHz only makes sense in certain scenarios
Reply
