Access Point still showing on Wireless Controller as offline after being physically removed (WM3400 & AP4600)
Userlevel 1
I'm currently using a WM3400 with AP4600s. (4620 in this case) We removed the AP4620 and replaced it, however it still appears on the web interface as offline. Is there a way to remove this AP from the controller so that others won't panic when they see the interface?
Userlevel 7
Hi Sean,
If you log into the CLI of the controller, then go into config mode, you can just do 'no ap4600 '. This will delete the device config for this AP.
-Brandon
Userlevel 1
Do I need to write to memory or anything else?
Userlevel 7
Yes, you will need to commit the changes and then save the config.
Userlevel 1
Thanks. 🙂 It was still there after I ran the command. For some reason the AP still showed up in the Config tab at which point I realized there's a delete button.... /sigh I deleted it and then commit/write and it went away from the dashboard. Appreciate the help! You can close this ticket!
Reply
