Question
Channel Invalid For Radio and Low Signal for AP 7562
  • 15 September 2020
  • 1 reply
  • 34 views
We have 7562 in our system and for radio2 i see this message “STATE                : Off [channel invalid for radio]”. Also despite 10.0 dbi 2.4 antenna and 5.9 dbi 5 GHZ antenna the access points are performing bad signal distribition. When i walk away 10 meters from AP, we are losing the signal.
1 reply
Radio: B8-50-01-74-4F-9C:R1, alias BILGIISLEM7562:R1
 STATE                : On
 PHY INFO             : Bssid: B8-50-01-90-91-70 RF-Mode: 2.4GHz-wlan
 ACCESS POINT         : Name: BILGIISLEM7562  Location: sueno  Placement: Outdoo                                                r
 CHANNEL              : Current: 1 Configured: smt Width: 20MHz
 TRANSMIT POWER       : 5 dBm
 ANTENNA USAGE        : 3x3
 MAXIMUM DATA RATES   : Phy: 288 Mbps User: 216 Mbps
 PHY SETTINGS         : Short Preamble: N Dual Channel: N Spectrum Mgmt: N
 RATE SELECTION       : Standard
 ANTENNA DOWNTILT     : Not-Supported
 RADIO SHARE MODE     : Off
 TRANSMIT BEAMFORMING : Enabled
 MU-MIMO              : Not-Supported
 SCAN_AHEAD CHANNEL   : -
 ERP COEXISTENCE      : ERP Protection: N Non-ERP detected: N Non-ERP associated                                                : N
 HT COEXISTENCE       : HT Protection: no-protection, Non-HT detected: N
 Current Channel Width: 20Mhz, reason: per configuration
 Num of Mcast Streams : 0 (max:256)
 Multicast streams    :
 # MP Mcast Streams   : 0
 WLAN MAP             :
     BSS-1            : SUENO_HOTELS* (*=primary)
     Shutdown WLANs   :
 MESHPOINT map        :
 BSS MAP              :
     BSS-1            : basic-rates    = 6 12 24
                      : supported-rates= 6 9 12 18 24 36 48 54 mcs-1s mcs-2s mcs-3s
 Last error           :
Radio: B8-50-01-74-4F-9C:R2, alias BILGIISLEM7562:R2
 PHY INFO             : Bssid: B8-50-01-90-9B-B0 RF-Mode: 5GHz-wlan
 ACCESS POINT         : Name: BILGIISLEM7562  Location: sueno  Placement: Outdoor
 CHANNEL              : Current: N/A Configured: smt Width: 20MHz
 TRANSMIT POWER       : 0 dBm
 ANTENNA USAGE        : 3x3
 MAXIMUM DATA RATES   : Phy: N/A User: N/A
 ERP COEXISTENCE      : ERP Protection: N Non-ERP detected: N Non-ERP associated: N
 Multicast streams    :
 WLAN MAP             :
     Shutdown WLANs   :
 MESHPOINT map        :
 BSS MAP              :
Reply
