Solved
Is there compatibility between Extreme Networks and Ubiquiti?
  • 24 July 2019
  • 2 replies
  • 141 views
Hi everyone
Could you help me? I need to know if AP7632 is compatible with US-8-150W Ubiquiti that they already have in their locations, would you have problems with POE power? or with the traffic to administer the AP? thanks so much
icon
Best answer by Chris Kelly 24 July 2019, 16:37
It says that it has 802.3af/at ports, so simply based on that alone, it *should* be able to power the 7632 w/o issue.
View original
Userlevel 5
You can use it normally. All POE standard AT use OK
Reply
