Max speed of new WiNG APs 7622 and 7602
Userlevel 2
Hi Community,
Two new APs 7622 and 7602 are have new operation modes as
concurrent single stream (1x1:2.4G + 1x1:5G), dual stream (2x2:2.4G or 2x2:5G), but i don't see the max speed each AP can reach in their datasheet.
So how is the actual max speed of them in two operation modes?
Userlevel 1
Max speed is listed at up to 867Mbps with 2 streams enabled on the 5Gzh band or 300Mbps with 2 streams enabled on the 2.4Ghz band. Half that per band in 1x1 mode on each radio.
Userlevel 2
Thank you Blake Williams.
This can be seen clearly in AP 7602 datasheet with MSC but with AP 7622, this isn't shown.
Do two this APs have same spec?
Userlevel 1
Yes, both AP's have the same radio specs.
good catch - I will fix the datasheet ... here is quick breakdown
MAX DATA RATES
RADIO BW MODE 2x2 MODE 1+1 MODE
2G radio 20 11N 144.4 72.2
5G radio 20 11AC 173.3 86.7
2G radio 40 11N 300 150
5G radio 40 11AC 400 200
2G radio 80 11N N/A N/A
5G radio 80 11AC 866.7 433.3
Userlevel 2
Thank you all so much.
Userlevel 1
Hi, is there going to be an external antennas 7622 version or is it just internal?
Userlevel 7
internal only...
http://www.extremenetworks.com/wing-access-points/
Userlevel 1
thank you
Userlevel 5
Captured this knowledge article based on the above conversation.
Max speed of WiNG APs 7622 and 7602
Reply
