mesh point with WLAN on radio1
Userlevel 2
Hello all,
Our regulation is not allows using of 5Ghz outdoor.
Sometimes we need to deploy outdoor AP's with mesh point and WLAN on 2.4Ghz only.
But as we see is working not so stable as we need - meshpoint links refreshed every several hours even if there is excellent signal and signal quality/noise level.
Please recommend some special recommendations for setting up mesh point with WLAN together on radio1.
Regards,
Aviv
Userlevel 4
Aviv, it's not clear what AP platform or what release you are running. And not clear what you have configured so it's hard to help you without that info.
Userlevel 2
Hello Alona,
There is the root AP conf example:
! Configuration of AP7131 version 5.8.4.0-034R
version 2.5
client-identity-group default
load default-fingerprints
ip access-list BROADCAST-MULTICAST-CONTROL
permit tcp any any rule-precedence 10 rule-description "permit all TCP traffic"
permit udp any eq 67 any eq dhcpc rule-precedence 11 rule-description "permit DHCP replies"
deny udp any range 137 138 any range 137 138 rule-precedence 20 rule-description "deny windows netbios"
deny ip any 224.0.0.0/4 rule-precedence 21 rule-description "deny IP multicast"
deny ip any host 255.255.255.255 rule-precedence 22 rule-description "deny IP local broadcast"
permit ip any any rule-precedence 100 rule-description "permit all IP traffic"
mac access-list PERMIT-ARP-AND-IPv4
permit any any type ip rule-precedence 10 rule-description "permit all IPv4 traffic"
permit any any type arp rule-precedence 20 rule-description "permit all ARP traffic"
ip snmp-access-list default
permit any
firewall-policy default
no ip dos smurf
no ip dos twinge
no ip dos invalid-protocol
no ip dos router-advt
no ip dos router-solicit
no ip dos option-route
no ip dos ascend
no ip dos chargen
no ip dos fraggle
no ip dos snork
no ip dos ftp-bounce
no ip dos tcp-intercept
no ip dos broadcast-multicast-icmp
no ip dos land
no ip dos tcp-xmas-scan
no ip dos tcp-null-scan
no ip dos winnuke
no ip dos tcp-fin-scan
no ip dos udp-short-hdr
no ip dos tcp-post-syn
no ip dos tcphdrfrag
no ip dos ip-ttl-zero
no ip dos ipspoof
no ip dos tcp-bad-sequence
no ip dos tcp-sequence-past-window
no ip-mac conflict
no ip-mac routing conflict
dhcp-offer-convert
no stateful-packet-inspection-l2
mint-policy global-default
meshpoint-qos-policy default
wlan-qos-policy default
qos trust dscp
qos trust wmm
radio-qos-policy default
wlan TEST
ssid TEST
vlan 1
bridging-mode local
encryption-type tkip-ccmp
authentication-type none
no broadcast-ssid
no answer-broadcast-probes
wpa-wpa2 psk 0 XXXXXXXXXX
use ip-access-list out BROADCAST-MULTICAST-CONTROL
use mac-access-list out PERMIT-ARP-AND-IPv4
shutdown on-primary-port-link-loss
meshpoint mesh1
meshid mesh1
beacon-format mesh-point
control-vlan 1
allowed-vlans 1
security-mode psk
root
management-policy default
telnet
no http server
https server
ssh
user admin password 1 82728d2cd05b08c2855b163cb0484fed7237a89c0691557d43b5a6c77e68b4fd role superuser access all
no snmp-server manager v3
snmp-server community 0 private rw
snmp-server community 0 public ro
snmp-server user snmptrap v3 encrypted des auth md5 0 admin123
snmp-server user snmpmanager v3 encrypted des auth md5 0 admin123
l2tpv3 policy default
profile ap71xx default-ap71xx
autoinstall configuration
autoinstall firmware
crypto ikev1 policy ikev1-default
isakmp-proposal default encryption aes-256 group 2 hash sha
crypto ikev2 policy ikev2-default
crypto ipsec transform-set default esp-aes-256 esp-sha-hmac
crypto ikev1 remote-vpn
crypto ikev2 remote-vpn
crypto auto-ipsec-secure
crypto remote-vpn-client
interface radio1
interface radio2
interface radio3
interface ge1
interface ge2
interface vlan1
ip address dhcp
ip address zeroconf secondary
ip dhcp client request options all
interface wwan1
interface pppoe1
use firewall-policy default
use client-identity-group default
logging on
service pm sys-restart
rf-domain default
timezone Etc/GMT+2
country-code il
ap71xx XX-XX-XX-XX-XX-XX
radio-count 2
use profile default-ap71xx
use rf-domain default
hostname AP2-root
license AP VIRTUAL_CONTROLLER_DEFAULT_AP_LICENSE
no adoption-site
ip default-gateway 172.XX.XX.254
interface radio1
wlan TEST bss 1 primary
meshpoint mesh1 bss 2
interface radio2
interface vlan1
ip address 172.XX.XX.202/24
no logging console
meshpoint-device mesh1
monitor primary-port-link action no-root
service meshpoint loop-prevention-port ge1
end
[/code]
[/code]On the other side is the non root AP.
Can you point me what may improve the stability of the mint links?
Thanks,
Aviv
Userlevel 2
Hello,
Any suggestions?
Thanks
Userlevel 4
Add following under radio 1:
no dynamic-chain-selection
rate-selection opportunistic
non-unicast tx-rate lowest-basic
You need to do this for both root and non-root. I assume this is 7131n . What antenna are you using? What gain? Distance between the APs? Why not 7161? AP 7131 went out of engineering support at this point.
Alona
Userlevel 2
Alona
Hi Alona,
We used AP7131int because we don't have AP7161 because of regulation problems (IL)
Thank you for your support.
Aviv
Hi Aviv,
From what I see you have channel at default (smt). When a meshpoint is mapped to a radio with smt set, which is the default, then mesh auto channel scan is enabled (smart-rf is not used when a meshpoint is mapped to a radio). By default, mesh auto channel will re-evaluate channel conditions every 30 minutes (channel hold time which is configured under meshpoint-device) e.g.
acs channel-hold-time 2.4GHz
Set this value to zero (0) to prevent the periodic re-evaluation.
When mesh auto channel is used, the channel list that is used is actually configured under the rf-domain. If nothing is defined then all channels will be scanned. Perhaps this is what you are seeing.
Also note, that you are using the default path method uniform which means path selection is metric based. Signal level is only one of many components that determine a path or path change. What do the metrics look like. Try these useful commands:
show wireless meshpoint neighbor statistics rf
show wireless meshpoint neighbor detail
show wireless meshpoint path detail
more system:/proc/dataplane/wireless/radio/radio1-proximity
To be sure you can enable debugging to see what the meshpoint is doing. With logging enabled, go to the cli and type "debug wireless meshpoint level debug". Wait for a change to occur and send me a tech dump.
Also, you do have CRM configured. I would also check the logs to see if there have been any CRM events.
Thank you,
Dan
Hi Aviv,
Correction, I did not mean CRM but primary-port-link. You may want to check and see if there have been any issues with interface going up and down causing a conversion.
Thank you,
Dan
Userlevel 2
Daniel DiLuzio wrote:
Hi Aviv,
Thank you,
Dan
Hi Daniel,
I talking about something global and not a specific issue, but thank you.
Regards,
Aviv
Reply
