Problem with roaming
Userlevel 2
Hi. I have a problem with roaming between aps with intermec ck3r devices in a delegation. the wifi system is composed of a vx9000 in central and an rfs4000 and several ap7522 in each delegation. in one of the delegations the terminals lose the connection when trying to do the roaming blocking the terminal application.
Userlevel 4
Do you use local traffic? I see issues like this, if you use local data and the VLAN is not available.
Some more details are useful.
Userlevel 5
See Q & A: why do my wireless clients not roam properly?
Reply
