Smart RF Power Calibration?
  • 22 October 2018
  • 17 replies
  • 1434 views
Userlevel 3
Hello,
I would like to know why in some RF-Domains the APs adopted in that RF-Domain ignore the minimum and maximum power values.
In an RF-Domain for example, I see that all Access Points are operating at full power. Is there a calibration process to be done?
Userlevel 6
Are you sure all the APs have the correct rf-domain policy with "SMART-MANAURA' policy applied to their profile?
Userlevel 3
Are you sure all the APs have the correct rf-domain policy with "SMART-MANAURA' policy applied to their profile? Hi Robert,
On Profile? Which option in the Profile must be checked for SMART RF to work?
Userlevel 3
Smart-RF is generating logs.
Userlevel 3
Help-me engineers
Userlevel 6
Help-me engineers
Can you show me output of CLI command 'sh run | in rf-domain' on ap that is showing radio in max power?
Userlevel 3
Help-me engineers
Good morning!
AP-11-SALA-DE-DESCANSO#sh run | in rf-domain
rf-domain-manager capable
rf-domain RF-MANAUARA
use rf-domain RF-MANAUARA
Userlevel 3
Help-me engineers
https://pastebin.com/BcDCzx8N
Smart-rf-config
https://pastebin.com/TzCAysuA
Userlevel 3
On this site we use ap7522.
Userlevel 4
Hi Richard,
Based on your initial screen shot smart-rf is not running.
Note:
All APs should not be on channels 1 & 36.
If code is lower than 5.9.0 i would advise an upgrade to later code.
If on 5.9.2 and above please un-check select shutdown
Can you also re-enable neighbor recovery?
If after 10-40 minutes of making the changes you are not seeing any changes please clear the smart-rf config.
Operations-> smart-rf -> -> clear config.
Note: this action may be disruptive to wireless clients.
See smart-rf guide for more details.
https://www.extremenetworks.com/support/documentation/smartrf/
If issue still persist after above changes I would recommend opening a support case.
Good morning, Daren.
Not have success in "clear config" on Smart RF.
We clear startup config and see operation w/ Smart RF. Before, we backup dump files for analysis w/ GTAC.
Userlevel 6
Hi Richard,
Note:
Hello Robert!
5.9.1.5
Userlevel 6
Hi Richard,
Note:
We have ap650 adopted in this vx. On ap7632 we use 5.9.2.4 VC.
Userlevel 6
Hi Richard,
Note:
Yes! We use ap7632 to work acting with VC because this limitation! Ap622 have support to WiNG 5.9.2, ap650 no.
Userlevel 3
Solved! I erased startup config. Smart RF works fine now!
Reply
