SNMP monitoring of amount of wireless clients connected on specific WLAN
Userlevel 2
Hello community,
I searching for SNMP monitoring of amount of wireless clients connected on specific WLAN/VLAN on the rf-domain.
VC - AP7532 WING 5.9+
I did not find it in the MIB.
Any ideas?
Thanks
Aviv K
Userlevel 2
Hi Aviv,
Unfortunately currently don't have SNMP OID that support client count per ssid or RF-domain for WiNG wireless.
But have SNMP OID that support client count on AP or radio.
Thanks
Userlevel 2
Hello Jian,
Thank you for you reply.
May be with VX9000 we have these options ?
Thanks
Userlevel 2
Aviv Kedem wrote:
Hello Jian,
Thanks
Hi Aviv,
As VX9000 also running WiNG OS, so is a WiNG wireless product.
Answer will be same as my first reply.
Thanks
Userlevel 2
Aviv Kedem wrote:
Hello Jian,
Thanks
Thank you
Reply
