Wireless Controller Web UI Problem
We have two wireless controllers (WM3600). but we are not able to access the webui of these controller. i can telnet with admin privileges but can't seem to access its web interface. is there any command which can be used to enable/disable webui of this controller. Thanks in advance.
Userlevel 6
It will only work with HTTPS. have you tried https://controller-ip
Thanks. it worked
Reply
