Solved
New APs - AP310/410/i/e are ignoring manual power settings
  • 15 April 2021
  • 4 replies
  • 61 views
We are experiencing issues with new APs and old MCs ( article on GTAC did not help) and we've noticed that radios often use max power at 10, occasionally 13 and very rarely 18 regardless of what is configured in Smart-RF policy and even ignores manual overrides. We even try not to use Smart-RF policy at all but it was still the same. Also CLI command "show wireless regulatory device-type ” doesn't show any info for these APs for any country - not sure if it's related or not.
Tested FWs 7.5.1.3 and 7.5.2.0
Any help appreciated
icon
Best answer by Ovais Qayyum 15 April 2021, 19:45
APs that run WiNG7 use a new regulatory table. If using external antennas, you need to specify the antenna model in the AP profile/device config, only then the AP would be able to make correct power calculations and Smart-RF will work correctly.
Check different antenna groups and pick the antenna that is installed on the AP:
Lab-VX(config-profile-AP410-AnyAP)#antenna-id external group-1 ?
  ah-acc-ant-ax-kt    AH-ACC-ANT-AX-KT Dual Band, 2.6dBi/4.2dBi
  ai-dq04360s         AI-DQ04360S Dual Band, Four Input Omni, 36 Inch Cable
  default             Internal antenna for internal SKU, auto select antenna
                      for external SKU
  ml-2452-apa2-01     ML-2452-APA2-01 3dBi/4.85dBi, dual band, black
  ml-2452-apa2-02     ML-2452-APA2-02 3dBi/4.85dBi, dual band, white
  ml-2452-hpa5-036    ML-2452-HPA5-036 3dBi/5dBi, dual band, outdoor, white
  ml-2452-hpag4a6-01  ML-2452-HPAG4A6-01 4dBi/7.3dBi, N-type male, dual band,
                      outdoor, white
  ml-2452-hpag5a8-01  ML-2452-HPAG5A8-01
  ml-2452-pna5-01r    ML-2452-PNA5-01R 2.4/5 GHz, Outdoor, Panel, 5 dBi, Beam
                      Width: E-Plane: 65 degrees, H-Plane: 120 degrees
  ml-2452-pna7-01r    ML-2452-PNA7-01R 8/12dBi 68deg Panel
  ml-2452-pta4m4-036  ML-2452-PTA4M4-036 4dBi/5 dBi, 4 port, dual band
  ml-2452-sec6m4-036  ML-2452-SEC6M4-036 DUAL POLARIZED DUAL BAND WIDE BEAM
                      DIRECTIONAL ANTENNA WITH 36 INCH CABLE
  ws-ai-2q05060       WS-AI-2Q05060 2.4GHz 60 DEG Sector
  ws-ai-5q04060       WS-AI-5Q04060 4dBI 60DEG SECTOR
  ws-ai-5q05025       WS-AI-5Q05025 5dBI 25DEG SECTOR
  ws-ai-de07025       WS-AI-DE07025 6.5/5DBi 25DEG sector
  ws-ai-de10055       WS-AI-DE10055 10/6DBi 55DEG sector
  ws-ai-dq05120       WS-AI-DQ05120 DUAL POLARIZED DUAL BAND WIDE BEAM
Regards,
Ovais
View original
Userlevel 5
Hi Michal,
It does show regulatory info, please see the following output from release 7.5.2.0:
Lab-VX#show wire regulatory device-type ap410i ca
  #  Channel Set Power(mW) Power (dBm) Placement      DFS          CAC(mins)
  1   1-11        4000      36          Indoor    Not Required   0
  2   36-48       1000      30          Indoor    Not Required   0
  3   52-64       1000      30          Indoor    Required       1
  4   100-116     1000      30          Indoor    Required       1
  5   120-128     1000      30          Indoor    Required       1
  6   132-144     1000      30          Indoor    Required       1
  7   149-165     4000      36          Indoor    Not Required   0
Are you using 410e/310e? For the external antenna AP versions you need to specify antenna in the same command to get the regulatory info.
Regards,
Ovais
Yes we are using external antena models. Thanks, I will try the command with specifying antenna type (for older APs - 7522 etc it wasn't necessary). But it still not solve main issue with ignoring configured power values.
Userlevel 5
                      for external SKU
                      outdoor, white
Regards,
Ovais
Thank you. Looks much better now. We usually do not use other than Extreme antennas but when we tried to change antenna gain on interface radio before (without changing/setting antenna-id ) it didn't help. I would expect same result from it as from antenna-id option.
Reply
