Solved
RF Planner Problem (Floor Plan)
  • 8 March 2021
  • 7 replies
  • 119 views
Hi Experts,
I know the RF Planner very well.
Since last week, in new projects, the saved floor plans are no longer displayed.
  • I can load plans
  • The plan is displayed.
  • After I changed the window, this plan is no longer displayed.
  • Error Message: Failed to download image
  • After that Message no Floor plan is visible.
Cheers
Joe
icon
Best answer by Sam Pirok 9 April 2021, 15:14
Hi @Johannes Grewe, could you send me a direct message with the name(s) of the Extreme Channel team members you reached out to? I’d like to find you different contacts to reach out to so we can get you some answers on this.
View original
Userlevel 6
Hi Joe, I’d recommend opening a support case for this so we can start collecting data from your specific XIQ instance to troubleshoot this with you.
Hi Sam,
i mean the online planning tool
https://wirelessplanner.extremenetworks.com/#/login
Our customers like the reports.
I know the IRIS an XIQ WiFi Planner integration, but I missing the great Reports.
Cheers
Joe
Userlevel 6
Hello!
Same issue.
Any solution?
Thank you!
Hello!
no solution.
I contacted the German Extreme channel team but nothing happened. what a shame.
Cheers
Joe
Userlevel 6
Hi Sam,
I also have the same problem for a few weeks.
I have opened a case but have not received a solution.
I have some projects blocked for this problem.
Thank you! Massimo
Userlevel 6
Thank you for letting me know @saronni@tech-id.it , could you share the case number with me so I can take a look? You can send that to me via a direct message here on the community or please feel free to email me at community@extremenetworks.com.
Reply
