Products
G-Series; firmware 6.61.06.0009, 6.61.07.0010
Changes
Pressed and held for 8+ seconds (the Hardware Installation Guide recommends 5 seconds) the '
code:
' button corresponding to a targeted IOM slot, in preparation for removing the IOM from that slot.POWER OFF
Symptoms
Unit reboot.
The current.log (5487) displays a "
code:
<[code]address[/code]>Task EDB BXS Resp(
code:
" message with last reset cause ") is suspended...
code:
"; for example:Fault(0x00000300)
- <[code]160[/code]>[code]Sep 3 03:43:37 172.17.8.120-1 SIM[104439944]: hwutils.c(7536) 762 %%[/code]
[code]ERROR:Code exception:Watchdog no longer being serviced.[/code]
[code]Task EDB BXS Resp(0x7fab848) is suspended with error 2, creating file sysDmp1Sep0312.z[/code]
<[code]57[/code]> [code]SEP 03 03:44:17 2012 BOOT[268430624]: bootos.c(1360) 760 %%[/code]
[code]Start of Code - Build:06.61.06.0009 Date:Wed Jul 25 18:47:14 2012[/code]
<[code]110[/code]> [code]SEP 03 03:44:20 2012 BOOT[153225176]: edb_bxs.c(1235) 764 %%[/code]
[code]Last switch reset caused by Fault(0x00000300) SRR0(0x01218D08) SRR1(0x0000B030) DMISS(0x00000000) IMISS(0x00000000) DAR(0x00002264) DSISR(0x0A000000)[/code]
code:
" and the diagnostic points to "Task Name: EDB BXS Resp
code:
"; for example:faultbias
- [code]Detailed exception task information[/code]
[code]---------------------------------[/code]
[code]Calling Stack:[/code]
[code]--------------[/code]
[code]Task ID:[/code] [code]0x7fab848[/code]
Task Name: [code]EDB BXS Resp[/code]
PC: [code]0x1218d08[/code]
[code]PendQ:[/code] [code]0x7f5184c[/code]
[code]SP:[/code] [code]0x7fa4df0[/code]
[code]0x1218d08: bfill (0x1218cbc) + 0x4c[/code]
[code]0x5ce30: faultbias (0x5b520) + 0x1910[/code]
[code]0x5f0dac: edbBxsRspTask (0x5ef044) + 0x1d68[/code]
[code]0x121b9c4: vxTaskEntry (0x121b968) + 0x5c[/code]
Upgrade to firmware 6.61.08.0013 or higher.
Pre-upgrade workaround: Avoid pressing the button for longer than 6 seconds.
