Products
SecureStack C5, C3, C2, B5, B3, B2
Changes
Issued the '
code:
<[code]index[/code]> set cos settings
code:
' command.priority...
Symptoms
The command was not accepted.
"Could not set the COS parameter"
For example:
- [code]C3(rw)-[/code]>[code]set cos settings 6 priority 6 tos-value 64[/code]
[code]Could not set the COS parameter[/code]
The Class of Service MIB (may be downloaded within mibs.zip) includes the following definition:
code:
iso.org.dod.internet.private.enterprises.enterasys.etsysMibs.etsysModules.etsysCosMIB.
code:
etsysCosObjects.etsysCos.etsysCosTable.etsysCosEntry.etsysCosIndex
code:
1.3.6.1.4.1.5624.1.2.55.1.3.5.1.1
code:
etsysCosIndex OBJECT-TYPE
code:
SYNTAX Unsigned Integer ( 0..32767 )
code:
MAX-ACCESS No Access
code:
STATUS Current
code:
DESCRIPTION
code:
A unique class of service identifier for this CoS setting.
code:
For reasons of backward compatibility indexes 0-7 MUST exist
code:
and be configured with a etsysCos8021dPriority which
code:
matches the etsysCosIndex.
code:
::= { etsysCosEntry 1 }
code:
MODULE ENTERASYS-CLASS-OF-SERVICE-MIB
code:
FILE
code:
enterasys-class-of-service-mib.txt
code:
PATH ftp://ftp.enterasys.com/pub/snmp/mibs
The command in question is defined as follows:
- [code]set cos settings[/code] <[code]Class of Service index 0-255[/code]>
[code][priority[/code] <[code]Priority 0-7 to be associated with the CoS[/code]>[code]][/code]
[code][tos-value[/code] <[code]TOS Byte value 0-255 to be written for the CoS[/code]>[code]][/code]
[code][irl-reference[/code] <[code]Inbound Rate Limiter 0-99 to be associated with the CoS[/code]>[code]][/code]
When a CoS Index value within the range of 8-255 is used, then it may be treated as a Class of Service which has a defined Priority value (0-7) associated with it.
When a CoS Index value within the range of 0-255 is used, then it may optionally be associated with a TOS Rewrite value and/or an Inbound Rate Limiter.
Solution/Workaround
FAD (Functions as Designed)
In order to avoid the stated cli error condition, it is necessary to
- Use a CoS Index value within the range of 0-7 only when it is desired that the resulting Priority match the index value;
-and-
When using a CoS Index value within the range of 0-7 do not specify a Priority value.
- [code]C3(rw)-[/code]>[code]set cos settings 6 tos-value 64[/code]
