How to configure wireless guest splash for the IdentiFi Wireless Solution
  • 25 September 2013
  • 0 replies
  • 931 views
Userlevel 3
Extreme Networks GTAC veteran Jason Noni describes How To create a wireless guest portal for wireless guest access on the IdentiFi Wireless Controller. This will enable you to create a guest portal for wireless users to authenticate to your IdentiFi wireless network.
Be the first to reply!
Reply
