Installation Manual for I-Series Power Supplies
Userlevel 3
Article ID: 10166
Products
I3H252
I3H-PWR
Solution
Manuals for the Enterasys I-Series Industrial Ethernet Switch include material specific to each of the I-Series components except the I3H-PWR power supply modules.
There are instructions for connecting the power supply to the switch, in the Hardware Installation Guide. This includes the following two items: Features
* DC Power
The I-Series switch requires 24 VDC input and can support a
redundant power source. For power supply specifications, refer to
"Power Requirements" on page A-3. Power supplies are not provided.
However, an AC to DC converter power supply, part number I3H-PWR,
is available to be purchased from Enterasys.[/code] Power Requirements
The power requirements for the I-Series switch are as follows:
Table A-8 Power Requirements
Electrical Specification
Input Power 24 VDC ~ 3.2 A
Power Consumption 18 to 36 Volt DC
0.93 to 1.87 A
33.48 to 33.66 W[/code]
Also, see the I-Series product page plus more literature for the I3H-PWR (Astec ADN2.5-24-1PM) 60 Watt Power Supply.
Be the first to reply!
Reply
