Power Cable for the 7C205-1 Power Supply in a 7C105-P Chassis
Userlevel 3
Article ID: 12137
Products
7C105-P, aka "N5"
7C205-1
Solution
For use in North America, power cable part# 5602019-URS1 (included) terminates in IEC C19 and NEMA 5-20P plugs, compatible with a 7C205-1 and a NEMA 5-20R 120-volt receptacle. The expected power draw is 15 amps.
For use in North America, power cable part# 5602019-URS2 (purchased separately) terminates in IEC C19 and NEMA 6-20P plugs, compatible with a 7C205-1 and a NEMA 6-20R 240-volt receptacle. The expected power draw is 8 amps.
For use in North American, you may optionally purchase a 5602019-US1 or 5602019-US2 (respectively).
["U"= United States, "R"= Right angle, "S" = Shielded, "1" = 120V, "2" = 240V]
For use outside North America, the correct power cables for the install location are included with each 7C205-1 purchased.
For more information, please refer to the 7C105-P Installation Guide.
Be the first to reply!
Reply
