SecureStack will not accept Cos Settings: "Could not set the COS parameter
  • 19 November 2014
  • 0 replies
  • 799 views
Userlevel 3
Article ID: 10323
Products
SecureStack C5, C3, C2, B5, B3, B2
Changes
Issued the '
code:
set cos settings
<[code]index[/code]>
code:
priority...
' command.
Symptoms
The command was not accepted.
"Could not set the COS parameter"
For example:
    [code]C3(rw)-[/code]>[code]set cos settings 6 priority 6 tos-value 64[/code] [code]Could not set the COS parameter[/code] [code]C3(rw)-[/code]>
Cause
The Class of Service MIB (may be downloaded within mibs.zip) includes the following definition:
code:
iso.org.dod.internet.private.enterprises.enterasys.etsysMibs.etsysModules.etsysCosMIB.
code:
etsysCosObjects.etsysCos.etsysCosTable.etsysCosEntry.etsysCosIndex
code:
1.3.6.1.4.1.5624.1.2.55.1.3.5.1.1
code:
etsysCosIndex OBJECT-TYPE
code:
SYNTAX Unsigned Integer ( 0..32767 )
code:
MAX-ACCESS No Access
code:
STATUS Current
code:
DESCRIPTION
code:
A unique class of service identifier for this CoS setting.
code:
For reasons of backward compatibility indexes 0-7 MUST exist
code:
and be configured with a etsysCos8021dPriority which
code:
matches the etsysCosIndex.
code:
::= { etsysCosEntry 1 }
code:
MODULE ENTERASYS-CLASS-OF-SERVICE-MIB
code:
FILE
code:
enterasys-class-of-service-mib.txt
code:
PATH ftp://ftp.enterasys.com/pub/snmp/mibs
The command in question is defined as follows:
    [code]set cos settings[/code] <[code]Class of Service index 0-255[/code]> [code][priority[/code] <[code]Priority 0-7 to be associated with the CoS[/code]>[code]][/code] [code][tos-value[/code] <[code]TOS Byte value 0-255 to be written for the CoS[/code]>[code]][/code] [code][irl-reference[/code] <[code]Inbound Rate Limiter 0-99 to be associated with the CoS[/code]>[code]][/code]
When a CoS Index value within the range of 0-7 is used, then it may be treated as a Class of Service or as a Priority (a legacy 802.1p Priority has a value within the range of 0-7), because for this range these concepts are synonymous.
When a CoS Index value within the range of 8-255 is used, then it may be treated as a Class of Service which has a defined Priority value (0-7) associated with it.
When a CoS Index value within the range of 0-255 is used, then it may optionally be associated with a TOS Rewrite value and/or an Inbound Rate Limiter.
Solution/Workaround
FAD (Functions as Designed)
In order to avoid the stated cli error condition, it is necessary to
    Use a CoS Index value within the range of 0-7 only when it is desired that the resulting Priority match the index value; -and- When using a CoS Index value within the range of 0-7 do not specify a Priority value.
The solution for the example given above is to omit the Priority parameter:
    [code]C3(rw)-[/code]>[code]set cos settings 6 tos-value 64[/code] [code]C3(rw)-[/code]>
Note that most often, NetSight Policy Manager - rather than the cli - is used to configure Policy and Class of Service.
Be the first to reply!
Reply
