I'm looking for the command to set the speed and duplex on an Enterasys port (100mbps full and 1gbps full) does anyone know the syntax and/or able to give me an example or point me to a good resource? Thanks in advance
Go with Caution.
For 1000BASE-T auto-negotiation are mandatory.
From: http://en.wikipedia.org/wiki/Gigabit_Ethernet
Autonegotiation is the Requirement for Using 1000BASE-T [9] according to Section 28D.5 Extensions required for Clause40 (1000BASE-T). [10]
Reply
Help
Shortcuts
Bold
Ctrl-B or Cmd-B
Italic
Ctrl-I or Cmd-I
Underline
Ctrl-U or Cmd-U
@Mention
@username
Upload image
Maximum file size: 2MB. Allowed image types: .jpg, .png, .gif.
We use cookies to enhance and personalize your experience. If you accept or continue browsing you agree to our cookie policy. Learn more about our cookies.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
