Setting and Clearing a 802.3ad Static LAG, on various products
Userlevel 3
Article ID: 6769
Products
DFE
Matrix C1
Matrix C2
Cause
The
code:
lacp static lag
command set, used for creating and removing Static Link Aggregation Groups, auto-generates a series of commands which then appear in the device configuration if they override factory defaults.
This document specifies the subcommands used for each product and operation.
Solution
Matrix DFE
How to create a Static LAG (example): Matrix N3(rw)->set lacp static lag.0.2 key 2000 ge.1.1-2
Issuing :
clear port lacp port ge.1.1-2 aadminstate all
clear port lacp port ge.1.1-2 padminstate all
clear port lacp port ge.1.1-2 aadminstate lacpactive
set lacp aadminkey lag.0.2 2000
set port lacp port ge.1.1-2 aadminkey 2000
set port lacp port ge.1.1-2 padminkey 2000
clear port lacp port ge.1.1-2 padminsysid
set port lacp port ge.1.1-2 disable
Matrix N3(rw)->[/code]
  • Lags are numbered lag.0.1 through lag.0.48.
  • Keys are numbered 0 through 65535.
  • Key specification is optional. If unspecified, a key will be assigned based on the referenced lag port. That is, keys 1-48 will be used, respectively, for lag.0.1 through lag.0.48.
  • The key value must be unique, on the local/actor device. If ports other than the desired underlying physical ports share the same admin key value, aggregation will fail or undesired aggregations will form.
How to remove a Static LAG (example): Matrix N3(rw)->clear lacp static lag.0.2 ge.1.1-2
Issuing :
clear port lacp port ge.1.1-2 padminkey
clear port lacp port ge.1.1-2 aadminkey
set port lacp port ge.1.1-2 enable
Matrix N3(rw)->clear lacp aadminkey lag.0.2
Matrix N3(rw)->[/code]The last command is necessary due to a bug in the '
code:
clear lacp static
' command, which does not fully reverse the commands issued by the '
code:
set lacp static
' command.
How to 802.1Q-trunk a LAG: 5038.
Further details are available in the Matrix DFE Configuration Guide.
Matrix C1
How to create a Static LAG (example): Matrix C1(rw)->set lacp static lag.1.2 key 1000 ge.1.8-9
Issuing :
clear port lacp port ge.1.8-9 aadminstate all
clear port lacp port ge.1.8-9 padminstate all
clear port lacp port ge.1.8-9 aadminstate lacpactive
set port lacp port ge.1.8-9 padminstate lacpagg
set lacp aadminkey lag.1.2 1000
set port lacp port ge.1.8-9 aadminkey 1000
set port lacp port ge.1.8-9 padminkey 1000
clear port lacp port ge.1.8-9 padminsysid
Matrix C1(rw)->[/code]
  • Lags are numbered lag.1.1 and lag.1.2.
  • At least two ports need to be assigned to a LAG port for a Link Aggregation Group to form and attach to the specified LAG port.
How to remove a Static LAG (example): Matrix C1(rw)->clear lacp static lag.1.2 ge.1.8-9
Issuing :
set port lacp port ge.1.8-9 disable
clear port lacp port ge.1.8-9 padminkey
clear port lacp port ge.1.8-9 aadminkey
set port lacp port ge.1.8-9 enable
clear lacp aadminkey lag.1.2
Matrix C1(su)->[/code]
Matrix C2
How to create a Static LAG (example): Matrix C2(rw)->set lacp aadminkey lag.0.5 422
Matrix C2(rw)->set port lacp port ge.1.8-9 aadminkey 422
Matrix C2(rw)->[/code]Note1: Though the '
code:
set lacp static
' command exists, it tends to lock up the cli (firmware 2.01.24, at least) and should not be used.
Note2: Because
code:
lag.0.5
's aadminkey has a default value of
code:
422
(recommended for use), the '
code:
set lacp
' command shown above is only necessary if a differing aadminkey value had been selected. It will only appear in the output of a '
code:
show configuration
' command if it differs from the default value.
    Lags are numbered lag.0.1 to lag.0.6.
  • The default Key values for lag.0.1 through lag.0.6 are 418-423, respectively.
How to remove a Static LAG (example): Matrix C1(su)->set lacp aadminkey lag.0.5 422
Matrix C1(su)->clear port lacp port ge.1.8-9 aadminkey
Matrix C1(su)->[/code]Note1: Though the '
code:
clear lacp static
Note2: Because
code:
lag.0.5
's aadminkey already has a value of
code:
422
, the '
code:
set lacp
' command shown above will not be necessary.
See also: 5531.
Further details are available in the Matrix C2 Configuration Guide.
Be the first to reply!
Reply
