Summit v15.3 with Fan Tray "out of operating range" error messages
Userlevel 3
Article ID: 16143
Products
Summit; EXOS version 12.6, 12.7, 15.1, 15.2, and 15.3 lines
Symptoms
Fan tray failure error messages.
Fan failure alarms while the LED flashes amber for the specific fans; for example:
code:
Warn:DM.Warning
code:
Switch, Error 4: Fantray 3 fan #6 failed. Rpm 18204 is out of operating range (from 4928 to 16800 rpm).
code:
Warn:DM.Warning
code:
Switch, Error 4: Fantray 2 fan #4 failed. Rpm 16948 is out of operating range (from 4928 to 16800 rpm).
Issuing the '
code:
show temperature
' command displays that the affected fans are "
code:
out of range
Solution
Upgrade to the latest available release or patch, based on the EXOS version currently in use.
For the EXOS 15.1 line, upgrade to 15.1.3-patch1-9 or higher.
ExtremeXOS 15.1.3-patch1-9 release notes state, in the '
code:
Resolved Issues
' section:
code:
Summit Family Switches
code:
PD4-3300688261
code:
Fan tray failure error messages occurs in Summit family switches.
For the EXOS 15.2 line, upgrade to 15.2.2-patch1-2 or higher.
ExtremeXOS 15.2.2-patch1-2 release notes state, in the '
code:
Resolved Issues
' section:
code:
Summit Series Switches
code:
PD4-3300688322
code:
Fan tray failure error messages appears on Summit family switches.
For any EXOS version, upgrade to 15.3(.1) or higher.
ExtremeXOS 15.3(.1) release notes state, in the '
code:
Resolved Issues
' section:
code:
code:
PD4-3206781851
code:
Fan tray failure error messages occur on Summit family switches.
Be the first to reply!
Reply
