ap3705i console connection
  • 20 April 2017
  • 1 reply
  • 1121 views
Dear All, i have try to connect to ap with console port with configuration Baud Rate: 9600, data bits 8 stop bits 1 and i cannot access the ap. Can anyone help to with this problem.
1 reply
Userlevel 4
Hi Shkelqim,
Please refer following link about console connection to AP37xx serise:
https://gtacknowledge.extremenetworks.com/articles/Q_A/AP3610-Console-Pinout/
Reply
