Can anyone tell me the range (coverage distance ) of Extreme Wireless 3825i AP ????
  • 11 April 2016
  • 2 replies
  • 505 views
I have checked the Datasheet of Extreme 3825i - But i cant able to find the exact distance its covers ??? I just want to know how much distance its covers (AP coverage distance)
Can any one help me in this ????
Userlevel 7
There is no value X as it depend on the environment.
That is the reason you'd need to do a site survey to get a actual measurement result of the signal, signal to noise, connection rate.
Thanks Ronald.
But I thought, It will be 300 to 400 meter by default..!!!
Thanks for your suggestion.!!
Reply
