Hi, I have a question. Is it possible to install a V2110 Controller at a KVM Virtuell Machine?
  • 1 April 2015
  • 2 replies
  • 1521 views
V2110 at KVM
Userlevel 4
Badge
Hello Frank,
its not official supported bey Extreme. Only VMware ESXi and Hyper-V are supported. But you can try to convert the .ova file to see if the vm boots. Maybe it works, but you would lose support.
Best Regards
Hartmut
Hello Frank,
Best Regards
Hartmut
Thanks for response
Reply
