Question
How long does ATPC need to be on to get to an accurate setting?
  • 20 February 2015
  • 3 replies
  • 755 views
Userlevel 2
When I have wi-fi issues and it seems coverage is low, I turn ATPC on for low-powered radios nearby and then turn it back off eventually. I'd like to turn it off sooner than later to minimize disruption and things I have to keep track of. We've 3610s mostly and some 3825s. Thanks!
Userlevel 2
Bueller? Bueller?
Userlevel 7
Normaly such information is included in the tech reference guide for the function/feature.
As such document is most of the time confidential I'm not sure whether someone will share that here.
So your best chance is to request the tech reference guide for ACS/ATPC from the GTAC.
Userlevel 2
Gotcha. Thank you sir.
Reply
