How to configure RADIUS login for management of the Enterasys Wireless Network Controller
Userlevel 3
Enterasys GTAC veteran Scott Whall describes How To enable RADIUS authentication for management login on the Enterasys Wireless Controller. This is used to authenticate persons that would manage the Enterasys Wireless Controller, enabling functions such as change control management.
Be the first to reply!
Reply
