Identify Wireless max power per country?
  • 14 October 2015
  • 4 replies
  • 498 views
Userlevel 3
Is there any document/datasheet/table which shows max Tx power per country and channel?
Thanks
Userlevel 7
Hello Rahman,
We do not publish those numbers.
Reference: https://gtacknowledge.extremenetworks.com/articles/Q_A/Why-can-I-not-set-the-access-point-power-to-the-maximum-supported-value
Userlevel 3
Hello Rahman,
I see, thanks anyway.
Userlevel 4
Badge
Wikipedia gives a overview:
https://en.wikipedia.org/wiki/List_of_WLAN_channels
Userlevel 4
I have wondered why the following footnote is on the WAP radio configuration page.
"Minimum power level is subject to the regulatory compliance requirement for the selected country"
Minimum power is regulated too?
Reply
