select antenna for ap3865e
  • 11 April 2016
  • 8 replies
  • 504 views
Hi everybody! Which antenna I can use to bridge two AP3865e at 1.5km for CCTV? Thanks you
Userlevel 7
In which country is the installation ?
In which country is the installation ?I install in Vietnam
Userlevel 7
In which country is the installation ?Vietnam isn't listed in the country pull down menu - so I assume the model isn't supported/certified for Vietnam (I've checked software v9 and v10).
Userlevel 7
In which country is the installation ?Thank Ronald, so can you try with Thailand for me?
Userlevel 7
In which country is the installation ?Thailand is available in the list, here the different antennas to choose from in the GUI...
Here the datasheet with the antennas on page#5
http://learn.extremenetworks.com/rs/extreme/images/IdentiFi-3865-Series-Outdoor-Access-Point-DS.pdf
You'd download the ExtremeWireless Estimator Tool V3.05.06 from the extranet to calculate the bridge link with the different antenna options.
https://extranet.extremenetworks.com/downloads/Pages/dms.ashx?download=fb745310-5069-455e-bb3e-60da1...
In which country is the installation ?Thank Ronald, I've choose my antennas
In which country is the installation ?Dear Mr Thinh can you support what kind of TV can support 1km for wi-fi outdoor
Thanks,
Hien Nguyen
Reply
