When Extreme Wireless V2110 Down in Bridge mode
  • 26 May 2015
  • 9 replies
  • 907 views
Hi Everyone,
V2110 : V9.15
AP : AP3825i
VNS Setting : Bridge Mode
1. SSID1: PSK + WPA2
2. SSID2 : MAC Auth with NAC
3. SSID3 : External Portal with NAC
When AP setting : Restart service in the absence of controller -> enable
Click to Enable or Disable (if using a bridged at AP VNS) to ensure
the AP continues providing service if the AP’s connection to the
controller is lost. If this option is enabled, it allows the AP to start a
bridged at AP VNS even in the absence of a controller.
When V2110(only one) Down,there is no Controller,but NAC is UP
SSID1 -> old session work fine
new session work fine
SSID2 -> old session work fine
new seesion can work ?
SSID3 -> old session not work
new seesion not work
How can I make SSID2 and SSID3 work fine with new session when V2110 down ?
Thanks
Regards,
Shooter
Userlevel 7
Take a look at:
http://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Maintain-Wireless-Services-upon-an-IdentiFi-Controller-Loss
Take a look at:
Thanks for your information,there is in detail.
So I have to using Controller Availability function ?
to avoid Controller down.
Userlevel 7
Take a look at:
Yes, that would be your best option as Ron described below. Both controllers should have the identical configurations for fast fail-over in the event an appliance goes offline...
-Doug
Take a look at:
Thanks for your help.
Userlevel 7
You'd use the feature "sites".
In short the AP act as the RADIUS client and send the request to the NAC.
But I think it's much easier to just run a second V2110 controller on another VM as standby.
And it's not that expensive also as you don't need to buy more AP licenses.
So I'd just get another VM controller for this "problem".
I will suggest customer to build two v2110 controller,
Userlevel 7
Scenario 3 is not supported in "Sites" mode....
Scenario 3 is not supported in "Sites" mode....Thanks for your information
Userlevel 7
Scenario 3 is not supported in "Sites" mode....No problem Shooter, good luck!
Reply
