wireless controller C100 Unmounting file systems:
  • 19 November 2013
  • 1 reply
  • 688 views
Problem Description: I have a controller c100 in version 3.1 ,i have onli CLI session with serial cable .
The led status remains off
When C100 was started I try to do software update ,but it failed and I can 't use GUI for configuration .
I can use only serial connection 9600 N8 1
Rebooting...
INIT: Sending processes the TERM signal
Stopping anacron: [ OK ]
Stopping keytable: [ OK ]
Shutting down console mouse services: [ OK ]
Stopping sshd:[ OK ]
Stopping xinetd: [ OK ]
Stopping crond: [ OK ]
Stopping portmapper: [ OK ]
Shutting down kernel logger: [ OK ]
Shutting down system logger: [ OK ]
Shutting down interface eth0: [ OK ]
Shutting down loopback interface: [ OK ]
Starting killall: [ OK ]
Sending all processes the TERM signal...
Sending all procmd: recovery thread got woken up ...
esses the KILL signal...
Syncing hardware clock to system time
Turning off swap:
Turning off quotas:
Please stand by while rebooting the system...
flushing ide devices: hda
Restarting system.
root (hd0,0)
Filesystem type is ext2fs, partition type 0x83
kernel /boot/vmlinuz ro root=LABEL=/ console=tty0
[Linux-bzImage, setup=0x1400, size=0x1101c6]
initrd /boot/initrd.img
[Linux-initrd @ 0x1ffbf000, 0x2028e bytes]
HiPath Wireless Controller version 3.1.3.00.06
Unauthorized access is prohibited.
HWC login: root
Password:
[root@HWC root]#
[root@HWC root]#
I have remote connection
Contact language: Italian, English only written
1 reply
Userlevel 7
Unfortunately this product is not something that was supported/offered by Enterasys or Extreme. If you are looking for a comparable replacement to this product, you should contact gsola@enterasys.com directly to discuss your options.
Regards,
Doug Hyde
Sr Support Engineer
Extreme Networks
Reply
