Enterasys transceivers on extreme switches
  • 12 November 2015
  • 5 replies
  • 909 views
Hi ,
I want to use the below transceivers on the extreme summit switches. If yes on which which summit switches.
MGBIC-LC-09
MGBIC-LC-01
Thanks
Syed
Userlevel 4
Syed Arshad,
It is possible that these Gigabit transceivers will work on EXOS switches; however, if possible put the optic in an EXOS switch and with a cable connected run the following command and provide the output.
debug hal show optic-info ddmi port
This output will provide some additional output.
I do not have them with me.
Did you try using them and they worked fine ?
Userlevel 4
You should try them yourself, in most cases 3rd party transceivers work well
Userlevel 4
There was a display issue is earlier firmware that would report "not supported " on some transceivers but that has been addressed so it is always a good point to upgrade but if the traffic passes without any issues you should be good to go.
Userlevel 4
The release notes are the go to documentation for these questions. If it is listed in a release as supported then it should be. If there are issues let us know.
Reply
