Extreme NCAP-500
  • 23 June 2015
  • 1 reply
  • 1293 views
Userlevel 1
Does nayone knwo hwo to factory default these APs?
Thanks
1 reply
Userlevel 4
Jeremy,
If you have console access to the AP you can try the following:
At login prompt type: reset
At the Password prompt type: FactoryDefault
This may be SW specific. From what I have researched there may be a reset button on the bottom but I do not believe it will reset.
Reply
