Extreme Networks Product Datasheet Archive
  • 13 October 2015
  • 8 replies
  • 1369 views
Userlevel 7
We've seen indications that our customers are looking for datasheets for products that are no longer sold. Once the products are removed from our website, this type of documentation becomes difficult to locate (we're working on this!). Here's how I can help - I'll keep this post updated with a list of the files that I have.
Most Extreme Networks product datasheets can be found here or here.
If you find yourself looking for a specific Extreme Networks product datasheet that isn't listed below or on our website, ask in this thread and I'll see what I can do. The list is small right now...
SummitX
BlackDiamond
ExtremeWare
Wireless
I hope this is helpful!
-Drew
Userlevel 3
Brilliant .. We are always being asked about the old hardware , there is still a lot out there .
Thanks
Rod
Userlevel 7
Hi Drew,
I would be interested in the older data sheets.
Did you find the BD20k data sheet (missing link in your post)?
Thanks,
Erik
Userlevel 7
Hi Drew,
Thanks,
Erik
Once I find out where the files should live, I'll post more of them. I've got the BD20k datasheet saved and ready.
Userlevel 7
Hi Drew,
Thanks,
Erik
Erik, links in the original post have been updated! Let me know if you'd like to see anything else.
Userlevel 7
Hi Drew,
Thanks,
Erik
Thanks!
Userlevel 1
How about the 7i? Looking to find max MACs it can hold. Look at datasheet, not there. Tried to find on release notes, couldnt find release notes. ty
Userlevel 7
The 7i... that's an old one!
I'll try to get this posted to the list above, but it won't help answer your question.
EDIT: Here's a snip from the ExtremeWare 6.2 Release notes that might answer it.
Reply
