Question
I would like to know the difference between 97003-R-BASE and 97003-R-DC-BASE
I would like to know the difference between 97003-R-BASE and 97003-R-DC-BASE.
Mainly the features in 97003-R-DC-BASE
Userlevel 6
Hello Dharmaraju
In Ridgeline the base is the number of licenses that are supported. The 97003-R-Base is SW service for just Ridgeline with no feature packs. The 97003-R-DC-Base is the SW support for Ridgeline with the DC feature license installed. I hope this helps.
P
Userlevel 6
A small correction to Paul's explanation.
97003-R-BASE is the Part # for ExtremeWorks Software Update Service for Ridgeline 4.x Base-50 (Part # 83019).
97003-R-DC-BASE is the Part # for ExtremeWorks Software Update Service for DC FP Base-50 (Part # 83527).
If you have Ridgeline 4.x Base-50 (Part # 83019) andDC FP Base-50 (Part # 83527) you need BOTH 97003-R-BASE and 97003-R-DC-BASE.
Reply
