Latest SSH Based Firmware for the EOL Summit 400-48t Switches?
  • 3 August 2015
  • 5 replies
  • 1477 views
Needing to get a link to the Latest SSH Based Firmware for the Summit 400-48t Switches.
Userlevel 6
hello Loren
Those switches have been end of support for many years. What version of code are you running?
Thanks
P
Userlevel 7
Hi Loren,
Normally these files are obtained through our eSupport site.
To make it a little easier for you, you can request the SSH images here: http://extrwebapps.extremenetworks.com/WebApps/Public/ExportControl/?swID=112
The file you want for your 400-48t is
code:
v784b1-patch1-4.SCxtr
. This is the last available ExtremeWare version.
Thanks a million that is exactly what was needed. Extreme Networks has my business when I upgrade in the future.
Userlevel 7
Thanks a million that is exactly what was needed. Extreme Networks has my business when I upgrade in the future.You're welcome Loren! Glad to help - and glad to hear that you'll come back to us! :)
-Drew
As an individual, as opposed being a representative of a corporate entity, I can NOT get access to the eSupport portal. That is the “ruling” from customer support.
I’d really like to update my 400-48T Ebay acquisition to the latest (technically last) firmware. Is there no way to get a copy of the aforementioned file? I’m having a tough time comprehending why it would be a bad thing to try to get the switch on its best possible footing.
Also, has anyone else had swollen capacitor issues with their 400-48T? I’ve had to replace a bunch of capacitors on the CPU board as they were bursting.
Reply
