Question
Old switches (B2, C2, C3 - Switch Management stop)
  • 25 July 2017
  • 0 replies
  • 522 views
Userlevel 5
I understand these switches are out of warranty and EoL and EoS, but maybe someone can give us some guidance?
A client of ours has a couple of the B2, C2, C3 switches deployed on the management VLAN for the Cape Town Data Centre.
For some reason the switch stops responding on its management interface. No ping, snmp etc. to the Managment IP or from the Management IP to any other IP.
When one connects via console cable to the switch you are able to ping the configured management IP locally, but nothing else on the same subnet.
One is even able to configure a laptop for the same subnet and plug it into another port on the switch and ping other IPs which comes in via an uplink cable.
From the core switch if I do a show neighbor, I can see the problematic switch:
sw-ctdc-core1(su)->sh neighbors ge.8.6
TYPES: LL = LLDP Ct = CtronDp Ci = CiscoDp
Port Device ID Port ID Ty Network Address
ge.8.6 00-1f-45-76-d5-68 ge.1.44 LL
ge.8.6 00-1f-45-76-d5-68 ge.1.44 Ct 172.25.250.185
ge.8.6 001f4576d568 ge.1.44 Ci 172.25.250.185
But from the problematic swich, I cannot see the core as a neighbor IP (although the correct port on the core is shown)
sw-ctdc-3rd-1(su)->show neighbors ge.1.44
Port Device ID Port ID Type Network Address
ge.1.44 20:B3:99:55:9F:D9 ge.8.6 lldp
sw-ctdc-3rd-1(su)-
One can even see the mac addresses of devices via the uplink port from the problematic switch:
sw-ctdc-3rd-1(su)->show mac port ge.1.44
MAC Address FID Port Type
00-00-5E-00-01-FA 1250 ge.1.44 Learned
00-10-F3-39-A3-40 1250 ge.1.44 Learned
00-10-F3-3F-0A-DE 1250 ge.1.44 Learned
00-11-88-1C-56-75 1250 ge.1.44 Learned
00-11-88-1C-56-ED 1250 ge.1.44 Learned
00-11-88-2C-32-B1 1250 ge.1.44 Learned
00-11-88-39-CB-6C 1250 ge.1.44 Learned
00-11-88-A9-F7-F0 1250 ge.1.44 Learned
00-11-88-ED-D4-AC 1250 ge.1.44 Learned
00-11-88-F6-7B-18 1250 ge.1.44 Learned
20-B3-99-55-49-AE 1250 ge.1.44 Learned
20-B3-99-55-9C-97 1250 ge.1.44 Learned
20-B3-99-55-9F-D9 1250 ge.1.44 Learned
20-B3-99-56-A8-E5 1250 ge.1.44 Learned
78-AC-C0-F1-4A-8F 1250 ge.1.44 Learned
B4-B5-2F-A5-2E-46 1250 ge.1.44 Learned
B4-B5-2F-A5-32-1A 1250 ge.1.44 Learned
And from the core it does learn the MAC of the problematic switch:
sw-ctdc-core1(su-router)->show mac port-string ge.8.6
MAC Address FID Port Type Status
20-B3-99-55-49-AE 0 ge.8.6 self
00-1F-45-76-D5-68 1250 ge.8.6 learned
Even the Router portion on the core does see the swtich (but cannot ping it) [Below is after I changed the local IP to 172.25.250.185
sw-ctdc-core1(su-router)->sh arp 172.25.250.185
LAGS: U = Unresolved S = Static
L = Local V = VRRP
* = Stale B = Best Guess Interface
H = Host Interest 2 = Secondary VLAN Entry
M = Main Router A = Proxy-All Entry
X = VxLan R = VxLan Remote
IP Address Hardware Address Flg Age Updated Interface Port
172.25.250.185 00-1f-45-76-d5-68 20m 20m vlan.0.1250 ge.8.6
ARP Entries Found: 1
I tried the following:
    Deleted the vlan (thus setting host vlan to 1) Deleted the IP address and put another one on in the same range Set the port between this switch and the core to 100Mbps Full Duplex without any auto-negotiation. Set the ports on this switch and on the core to the management VLAN untagged. Disabled spanning tree on these ports. Clear arp all
The switches are on the latest firmware available. 06.61.16.0002
The uptime is fairly recent as well: 66,8:18:55
Any comments would be appreciated.
Be the first to reply!
Reply
