summit200-48 only 24 port can get ip, what is problem?
hi
i have summit200-48 port,
i configured and it seems that every thing is okay,
but only users on ports 1-24 can get ip , but othe ports cannot.
Extremeware Version 7.1e.2 (Build 1)
this is my config:
# Config information for VLAN Default.
configure vlan "Default" tag 1 # VLAN-ID=0x1 Global Tag 1
# No QoS Profile configured for VLAN Default.
# Config information for VLAN z1-v6.
configure vlan "z1-v6" ipaddress 172.16.38.1 255.255.255.0
configure vlan "z1-v6" add port 1 untagged
configure vlan "z1-v6" add port 1 mac-limit no-limit
configure vlan "z1-v6" add port 2 untagged
configure vlan "z1-v6" add port 2 mac-limit no-limit
configure vlan "z1-v6" add port 3 untagged
configure vlan "z1-v6" add port 3 mac-limit no-limit
configure vlan "z1-v6" add port 4 untagged
configure vlan "z1-v6" add port 4 mac-limit no-limit
configure vlan "z1-v6" add port 5 untagged
configure vlan "z1-v6" add port 5 mac-limit no-limit
configure vlan "z1-v6" add port 6 untagged
configure vlan "z1-v6" add port 6 mac-limit no-limit
configure vlan "z1-v6" add port 7 untagged
configure vlan "z1-v6" add port 7 mac-limit no-limit
configure vlan "z1-v6" add port 8 untagged
configure vlan "z1-v6" add port 8 mac-limit no-limit
configure vlan "z1-v6" add port 9 untagged
configure vlan "z1-v6" add port 9 mac-limit no-limit
configure vlan "z1-v6" add port 10 untagged
configure vlan "z1-v6" add port 10 mac-limit no-limit
configure vlan "z1-v6" add port 11 untagged
configure vlan "z1-v6" add port 11 mac-limit no-limit
configure vlan "z1-v6" add port 12 untagged
configure vlan "z1-v6" add port 12 mac-limit no-limit
configure vlan "z1-v6" add port 13 untagged
configure vlan "z1-v6" add port 13 mac-limit no-limit
configure vlan "z1-v6" add port 14 untagged
configure vlan "z1-v6" add port 14 mac-limit no-limit
configure vlan "z1-v6" add port 15 untagged
configure vlan "z1-v6" add port 15 mac-limit no-limit
configure vlan "z1-v6" add port 16 untagged
configure vlan "z1-v6" add port 16 mac-limit no-limit
configure vlan "z1-v6" add port 17 untagged
configure vlan "z1-v6" add port 17 mac-limit no-limit
configure vlan "z1-v6" add port 18 untagged
configure vlan "z1-v6" add port 18 mac-limit no-limit
configure vlan "z1-v6" add port 19 untagged
configure vlan "z1-v6" add port 19 mac-limit no-limit
configure vlan "z1-v6" add port 20 untagged
configure vlan "z1-v6" add port 20 mac-limit no-limit
configure vlan "z1-v6" add port 21 untagged
configure vlan "z1-v6" add port 21 mac-limit no-limit
configure vlan "z1-v6" add port 22 untagged
configure vlan "z1-v6" add port 22 mac-limit no-limit
configure vlan "z1-v6" add port 23 untagged
configure vlan "z1-v6" add port 23 mac-limit no-limit
configure vlan "z1-v6" add port 24 untagged
configure vlan "z1-v6" add port 24 mac-limit no-limit
configure vlan "z1-v6" add port 25 untagged
configure vlan "z1-v6" add port 25 mac-limit no-limit
configure vlan "z1-v6" add port 26 untagged
configure vlan "z1-v6" add port 26 mac-limit no-limit
configure vlan "z1-v6" add port 27 untagged
configure vlan "z1-v6" add port 27 mac-limit no-limit
configure vlan "z1-v6" add port 28 untagged
configure vlan "z1-v6" add port 28 mac-limit no-limit
configure vlan "z1-v6" add port 29 untagged
configure vlan "z1-v6" add port 29 mac-limit no-limit
configure vlan "z1-v6" add port 30 untagged
configure vlan "z1-v6" add port 30 mac-limit no-limit
configure vlan "z1-v6" add port 31 untagged
configure vlan "z1-v6" add port 31 mac-limit no-limit
configure vlan "z1-v6" add port 32 untagged
configure vlan "z1-v6" add port 32 mac-limit no-limit
configure vlan "z1-v6" add port 33 untagged
configure vlan "z1-v6" add port 33 mac-limit no-limit
configure vlan "z1-v6" add port 34 untagged
configure vlan "z1-v6" add port 34 mac-limit no-limit
configure vlan "z1-v6" add port 35 untagged
configure vlan "z1-v6" add port 35 mac-limit no-limit
configure vlan "z1-v6" add port 36 untagged
configure vlan "z1-v6" add port 36 mac-limit no-limit
configure vlan "z1-v6" add port 37 untagged
configure vlan "z1-v6" add port 37 mac-limit no-limit
configure vlan "z1-v6" add port 38 untagged
configure vlan "z1-v6" add port 38 mac-limit no-limit
configure vlan "z1-v6" add port 39 untagged
configure vlan "z1-v6" add port 39 mac-limit no-limit
configure vlan "z1-v6" add port 40 untagged
configure vlan "z1-v6" add port 40 mac-limit no-limit
configure vlan "z1-v6" add port 41 untagged
configure vlan "z1-v6" add port 41 mac-limit no-limit
configure vlan "z1-v6" add port 42 untagged
configure vlan "z1-v6" add port 42 mac-limit no-limit
configure vlan "z1-v6" add port 43 untagged
configure vlan "z1-v6" add port 43 mac-limit no-limit
configure vlan "z1-v6" add port 44 untagged
configure vlan "z1-v6" add port 44 mac-limit no-limit
configure vlan "z1-v6" add port 45 untagged
configure vlan "z1-v6" add port 45 mac-limit no-limit
configure vlan "z1-v6" add port 46 untagged
configure vlan "z1-v6" add port 46 mac-limit no-limit
configure vlan "z1-v6" add port 47 untagged
configure vlan "z1-v6" add port 47 mac-limit no-limit
configure vlan "z1-v6" add port 48 untagged
configure vlan "z1-v6" add port 48 mac-limit no-limit
# Config information for VLAN uplink-z1-v6.
# No QoS Profile configured for VLAN uplink-z1-v6.
configure vlan "uplink-z1-v6" ipaddress 172.16.4.194 255.255.255.252
configure vlan "uplink-z1-v6" add port 49 untagged
configure vlan "uplink-z1-v6" add port 49 mac-limit no-limit
# Config information for VLAN uplink-z1-v10.
# No QoS Profile configured for VLAN uplink-z1-v10.
configure vlan "uplink-z1-v10" ipaddress 172.16.4.65 255.255.255.252
configure vlan "uplink-z1-v10" add port 50 untagged
configure vlan "uplink-z1-v10" add port 50 mac-limit no-limit
# Access-mask Configuration
# Access-list Configuration
# Rate-limit Configuration
# Syslog configuration
configure log display debug
enable log display
# Management Configuration
enable web
# SNMP Configuration
configure snmp add trapreceiver 172.16.33.13 community "ST.-1408229107.10550"
configure snmp add trapreceiver 172.16.33.155 community "ST.-1408228965.10550"
configure snmp add trapreceiver 172.16.33.37 community "ST.-1408229083.10550"
configure snmp add trapreceiver 172.16.33.53 community "ST.-1408229067.10550"
configure snmp delete community readonly all
configure snmp delete community readwrite all
configure snmp add community readonly encrypted "rykfcb"
configure snmp add community readwrite encrypted "r~'|kug"
configure snmp add community readonly encrypted "ouy#uhmkg"
configure snmp sysName "Summit200-48"
enable rmon
# Port Configuration
# Spanning tree information
# MAC FDB configuration and static entries
# -- IP Interface[0] = "Default"
# -- IP Interface[1] = "z1-v6"
enable ipforwarding vlan "z1-v6"
# -- IP Interface[2] = "uplink-z1-v6"
enable ipforwarding vlan "uplink-z1-v6"
# -- IP Interface[3] = "uplink-z1-v10"
enable ipforwarding vlan "uplink-z1-v10"
# Global IP settings.
enable bootprelay
configure bootprelay add 172.16.33.4
configure bootprelay add 172.16.33.5
# IP ARP Configuration
# IP Route Configuration
# Multicast configuration
# RIP interface configuration
config rip add vlan "uplink-z1-v10"
config rip add vlan "uplink-z1-v6"
config rip add vlan "z1-v6"
# RIP global parameter configuration
# RIP Global enable/disable state
enable rip
# PIM Router Configuration
# Ospf Area Configuration
# Ospf Range Configuration
# Interface Configuration
# Virtual Link Configuration
# Ospf ASE Summary Configuration
# OSPF Router Configuration
# EAPS configuration
# NAT configuration
configure nat timeout 300
configure dns-client add 172.16.33.4
configure dns-client add 172.16.33.5
configure dns-client add 172.16.33.2
# SNTP client configuration
# Mac Vlan Configurations
# Network Login Configuration
enable netlogin Session-Refresh 3
# End of configuration file for "Summit200-48".
Summit200-48:2 #
Userlevel 6
This is a very old switch, running a version that is not the latest, I would suggest to upgrade to the latest possible ExtremeWare version (7.8.x) and see how it behaves then. The config looks good, I see no problems there.
Userlevel 2
Try resetting ports , cables and swapping hosts if possible. If still it doesn't help, next option is to upgrade like Oscar suggested.
Reply
