How to enable STP in Extreme Switches?
  • 4 December 2015
  • 4 replies
  • 5341 views
Userlevel 1
is it possible configure STP for selected Ports alone? If possible please share the stps...
Userlevel 4
Hi Thavamani,
Take a look the GTAC Knowledge article How to configure RSTP in EXOS
Userlevel 5
Hi Thavamani, By default, the Default VLAN is already a member of STP Domain s0. If you created any additional VLANs, you could add those ports to the STP s0 domain using the following command:
configure stpd add vlan ports [/code]The above command allows you to be specific about the ports you want to add. If you do however wish to add all the ports, the auto-bind feature outlined in the article Dorian provided can be very handy.
Userlevel 1
Hello Thavanami, I have the script of the configuration of the STPD. Do you question is about spanning-tree or STP ( Software of the inline-power - POE )?
Send my script of spanning-three.
create stpd EX: VLan: 2000 --> STPD_2000config stpd add vlan ports [u] emistp
config stpd add vlan ports dot1d
or
config stpd ports link-type edge edge-safeguard enable bpdu-restrict
config stpd tag
config stpd mode dot1w
enable stpd
enable stpd
Userlevel 1
You can use the commands to see the stpd working.
show stpd
or
show stpd < name stpd >
Reply
