Question
hw problems with B5G124-48
  • 22 October 2019
  • 0 replies
  • 521 views
Hello,
We have a stack with B5G124-48 switches and we have some problems with hardware. One switch of them is resetting continuosly and in other switch, I think that some ports are bad because the switch run OK, leds OK but when connect the cable, the port is OFF.
Is there any way to pass a checking procedure of hardware?
Thanks in advance!!!
Best regards,
Igor
Be the first to reply!
Reply
