lost operational code / firmware due to internal battery replacement ?
  • 1 October 2014
  • 28 replies
  • 1742 views
After some years of use we stop and clean C3G124-48 and also replace internal bateries after doing that never more the switch boot up to operational code.
We think the system lost the firmware due to replacement of this battery (is this possible??)
The system goes only to this line and stops.
Enterasys C3-Series Boot Code...
SDRAM Circuit Test of 255MB
100%
How is possible to load again the firmware to the unit on this status.
Thanks in Advance
Userlevel 1
Badge
Try use XModem metod
Article ID: 5605 Firmware Upgrading a SecureStack via TFTP or XModem
Thanks for reply,
We know this method but on this case the procedure maybe will be "Empty Unit Firmware Loading" because is not possible to access boot menu, to use standard ID5605 method....
Cheers,
Solved !!
Symptom:
On C3 system if you replace internal battery CR2032 with the switch off you lost some boot flag or data that makes the device does not boot anymore to op code, remaining on this status.
100%
Solution
With a cable we use oscilloscope prove make connection between ground on any point at the board and the pin 28 of U19 Intel JS28F128J3D75 flash memory this pin is A1 address bus pin, this make the Freescale processor jump to some instruction with result like this.
ERROR! Did not read a valid board type from PCA9555 Monitor. Read -1
Unknown box topology
cfiscsByteWrite:Flash MTD: CFISCS write failed in verification.tffsDevCreate failed.
usrTffsConfig of drive 1 returned 0xffffffff, formatting 33554432 bytes...
Format complete. Please power cycle the box.
After make the power cycle make it again and get something like this.....
Enterasys C3-Series Boot Code...SDRAM Circuit Test of 255MB
100%
Version 01.00.53 01-16-2012
Computing MD5 Checksum of operational code...
Operational code CRC is invalid.
Boot Menu Version 01.00.53 01-16-2012
Options available
1 - Start operational code
2 - Change baud rate
3 - Retrieve event log using XMODEM (64KB).
4 - Load new operational code using XMODEM
5 - Display operational code vital product data
6 - Update Boot Code
7 - Delete operational code
8 - Reset the system
9 - Restore Configuration to factory defaults (delete config files)
10 - Set new Boot Code password
[Boot Menu] 9
[Boot Menu] 5
ERROR: Operational code CRC is not valid.
[Boot Menu]
Proceed like the normal XMODEM upload procedure.
After loaded firmware and CRC OK, save config and restart, that's all.
Userlevel 2
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
Hello Mike, I have same problem, I am able to access boot menu and upload new FW by Xmodem. Problem is, that it success upload, update boot code and run into operational mode, but after reset it wont boot. I have to to same thing with short 28pin of memory every time to get unit boot. Any ideas?
Userlevel 2
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
Solved: I had to flash few major version older fw so it flash "PROM". New PROM was also in 06.61.05.0009....Just flashing latest version is unsuficient.
Userlevel 6
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
Welcome to the Hub Feldsam....great to have you join us.
Better yet, great that you found a resolution to your problem. Thanks for letting the Community know.
I noticed that this thread pre-dates GTAC Knowledge, so thought I'd throw a link in an applicable article for those in the future that read this thread.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-upgrade-Securestack-Firmware
https://community.extremenetworks.com/extreme/topics/firmware_upgrading_a_securestack_via_tftp_or_xm...
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
I have the same issue. Could you help me with that?
Userlevel 2
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
hello, as I wrote, you need to flash FW version 06.61.05.0009 which contains PROM also.
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
Thanks for your really quick response@feldsam
But I don´t know how to do that.
I have open a serial connection to the switch and the only message I can see is this:
100%
Then it does nothing.
T&R
Userlevel 2
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
Hi, you probably doesn't read carefully what Mike F. wrote in his post. Return and read again :)
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
I did read that, but I don´t understand it. 😃
Userlevel 2
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
did you open unit? how your problem happens? If you did not open unit and never try to replace battery them your battery is probably dead. So you need new battery, open unit, replace battery, localte that Intel chip. Conenct serial cable, connect power and short cut ground with U19 chip pin 28. Them you should see something about flash format, unit reboots and boot menu should show. you probably need to short cut circuit more times to get boot menu. them flash via xmodem firware version 06.61.05.0009, boot, save config and reboot. unit should be ok.
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
Thank you so much for your assistance. I will replace the battery and google for some information about short cutting that chip.
Thanks!
Userlevel 2
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
there is nothing to google 🙂 just open case and look for Intel chip marked U19. Dot marks pin number 1, so you have to count to 28, but you dont have, because this chip has 28pins on each side, so 28pin is on other end that pin 1. https://www.usbid.com/assets/partphotos/6B/JS28F128J3D75.jpg
Userlevel 2
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
https://postimg.org/image/3vh13g7cl/
Userlevel 2
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
so it is pretty simple, jut conenct by wire GND - some point on case with that pin 28
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
Thank you SO MUCH for your help.
But I have a problem. My switch model is different C2G124 and I can not see that chipset.
http://es.tinypic.com/view.php?pic=262m92e&s=9#.WUKKhVElGUk
T&R
Userlevel 2
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
what about other side of that board? and is that board connected to another one?
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
http://es.tinypic.com/view.php?pic=bl7nt&s=9#.WUKQrlElGUk
this is the other side
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
and it is connected here:
http://es.tinypic.com/view.php?pic=2yye715&s=9#.WUKRS1ElGUk
Userlevel 2
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
you sent me same side just 90 rotated. would you please post other side of that board?
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
sorry!
http://es.tinypic.com/view.php?pic=sndl3m&s=9#.WUKSY1ElGUk
Userlevel 2
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
hmm, probably try that empty space for chip E28F128J3A, spot 28.
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
So, you mean, connect the power and with a wire touch the box, and that spot 28 of the chip : E28F128J3A ??
It is safe for the electrical installation? I don´t care about the switch
Userlevel 2
Solved !!
Symptom:
100%
Solution
100%
Options available
[Boot Menu] 9
[Boot Menu] 5
[Boot Menu]
yes, correct. I use for this cheap multimeter in current mode. https://www.homepower.com/sites/default/files/uploads/3_cheap-meter.jpg
Reply
