01-02-2024 10:17 AM
I know in Cisco switches I can pull state changes and get a date for the last time a port was active, but for the life of me I cannot find that option on our Aerohive branded switches, Extreme branded switches, or within ExtremeCloud IQ.
Do you know of any way I can pull reports to help find unused ports either through SSH or through ExtremeCloud IQ?
I have searched the community, but most seem to point to some Extreme Management Suite that we are not running.
TIA
Ben
Solved! Go to Solution.
01-02-2024 03:13 PM
Hi Ben,
For EXOS (Extreme Switches) you can do it via SSH/CLI:
show ports informationThis will display a consolidated overview of all ports that shows - among other things - if a port was ever up since the last boot. This can be used to filter out these ports quickly.
show ports information detailThis will display the last link up / link down of ports.
By default both commands show the output for all ports, this can be limited.
show ports 1 information detail
show ports 1,4,7 information detail
show ports 1-24 information detail
01-12-2024 05:08 AM
I use this to filter just what I want on EXOS
show port 1:1 info detail | include "Port:|Link State:|Link Ups:|Link Downs"
01-04-2024 05:52 AM
Thanks for the update. I wish those worked on HiveOS as a majority of our switches are running on that. The only way I could see is either through some monitoring utility, which I don't have, or clearing the counters and trusting that.
01-02-2024 03:13 PM
Hi Ben,
