AP630 not booting - flashing white amber
mihai_balaci
New Contributor III
Hi community,
The AP is not booting. I think I need to connect via console, but from a mac I can't make it work.
does anyone had a guite on how to connect to the device via console?
or I can force reset it in any way?
thank you
1 ACCEPTED SOLUTION
shirley58
Hello,
To connect to your AP via console from a Mac, you'll need a USB-to-serial adapter and a console cable. Open the Terminal application on your Mac, then use ls /dev/cu.* to identify your serial device (it will often be something like /dev/cu.usbserial-XXXXX). Once identified, connect using the screen command, e.g., screen /dev/cu.usbserial-XXXXX 115200 (adjust baud rate as per your AP's specifications, common rates are 9600 or 115200). To force reset without console, most APs have a small physical reset button (often recessed, requiring a paperclip) that you can press and hold for about 10-30 seconds while powered on; consult your specific AP model's manual for the exact procedure and duration.
2 REPLIES 2
mihai_balaci
New Contributor III
thank you a ton.
shirley58
Hello,
