view difference between the running configuration and startup configuration with EXOS
06-09-2016 08:25 AM
How can display the difference between the running configuration and startup configuration with EXOS
3 REPLIES 3
06-09-2016 08:51 AM
Hi Chandip,
There isn't an official supported way to do this, however there is a script on our GitHub that will get this done:
https://github.com/extremenetworks/ExtremeScripting/tree/master/EXOS/Python/conf_diff
06-09-2016 08:51 AM
HI Brad
Thanks for the prompt reply. I should of stated without scripts in my original question. It seems we can achieve most things with the scripts J.
It’s just not practical when viewing remote sessions with the customer. A “show running-config diff” would be nice. I will put in a feature request for this.
Thanks
Chandip
Thanks
Chandip
06-09-2016 08:51 AM
There is an important caveat to the script that I felt should be mentioned. The script will remove the asterisk (or dirty bit) from the prompt. Under the hood, the script saves the configuration to a temporary file and then deletes the temporary file. Since the configuration technically gets saved to that temporary file, the dirty bit is cleared.
You'll need to actually save your configuration changes should you want to do so.
