What is the difference between an untagged port and a tagged port?
  • 16 December 2015
  • 12 replies
  • 728 views
What is the difference between an untagged port and a tagged port ? when can I using them & what is the benefit?
Userlevel 6
Vlans should be tagged on switch to switch links.
Untagged will determine the dhcp address you get back from the server.
Tagged is also good for your elrp vlan. We tend to run a vlan called No_loop on tagged on all ports and use it for our elrp config.
Userlevel 7
Did you see this thread when creating this one?
https://community.extremenetworks.com/extreme/topics/what_are_tagged_and_untagged_ports-pnil4
thank you
Userlevel 6
This is a pretty solid explanation as well:
https://gtacknowledge.extremenetworks.com/articles/How_To/Understanding-EXOS-VLANS-and-tagged-and-un...
great , just i need know What is the function untagged, with what use, witch the benefit ?
Userlevel 6
End user devices will need to be on an untagged vlan to get to the internet.
Userlevel 2
I think you also need to 'untag' the native vlan (not default vlan) on any trunk ports.
Userlevel 7
I think you also need to 'untag' the native vlan (not default vlan) on any trunk ports.Using a "native VLAN" on a trunk means not tagging this VLAN. This is not needed for Extreme EOS nor ExtremeXOS. I would recommend to tag every VLAN on any inter-switch-link. Note that some special configurations (e.g. RSTP on EXOS) do require a native VLAN, but those situations can usually be avoided (e.g. using MSTP instead of RSTP).
thanks o/
Userlevel 7
thanks o/
\o
this is what I actually do:
Tagged = T = trunk for VLAN
Untagged = U = untrunk = switchport for VLAN
Userlevel 5
Another post for Tag and Untag
What are tagged and untagged ports?
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-are-tagged-and-untagged-ports/?q=tag+vla...
Best regards,
Reply
