Extreme AP Configuration
  • 21 October 2014
  • 8 replies
  • 1055 views
I am trying to setup an AP 3825i to perform a site survey. I am trying to access the CLI to set the config, however, I apparently do not have the default login credentials (admin/admin123 don't work). Does anyone have the correct default login credentials?
Userlevel 7
admin/new2day but even that will not solve the problem as the AP has no standalone mode
The only way to do it is... short version....
- connect AP to WLAN appliance
- setup a wlan service/topology/VNS that is bridge@AP untagged
- set the antenna. static channel, tx power and all the other radio settings
- in "AP properities" in the advanced section select "Maintain client sessions in event of poll failure" and "Restart service in the absence of controller"
Now you'd unplug the AP and use it for a site survey.
ah...ok. thought the AP did have standalone mode. will set up per advised recommendation.
thanks.
Userlevel 5
thanks.
Shane,
The following KB Article would help you to configure an AP for site survey:-
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-setup-an-IdentiFi-thin-access-point...
hi
Is this possible to configure AP 3805i in standalone?
If it possible please let me know....
Userlevel 7
Yes&No.
There is no standalone mode but as mentioned above you'd configure a controller AP to act like a standalone AP.
That is possible with all controller APs also with the AP3805i.
ok, we can configure ap standalone by controller....right
Userlevel 7
You can configure "Maintain client sessions in event of poll failure" via the controller GUI.
ok got it
thank u
Reply
