Hi to all.
My name is Simon from from Slovenia (EU).
We are dealing with medical devices.
We have one telemetry system like this one:
https://www.mindray.com/en/product/BeneVision_TM80.html
We need to install it in one old hospital where are very thick brick walls (20 cm).
If you imagine structure of department. You have hallway and then you have on left and right site patient rooms , where patients will use telemetry receivers.
So right now there are installed your AP model 3915i on the middle of the hallway.
And now we have problems with receiving signal by the end of patient rooms (at windows).
So now I am trying to find if Extremenetworks have some AP portfolio with wider range or maybe it would help maybe some AP with external antennas. Or there is just option that we increase number of AP (inside the patient rooms). Orr there are some special AP’s recommended for hospital environment.
Maybe do you have some suggestion?
I could send you also more details.
Thank you in advance.
With kind regards, Simon
